1469 Vistas, 10 Respuestas
Mac OSX Security Update 2020-005 prevents Autocad LT 2021.1 for MAC starting
Applied the Mac OSX Security Update 2020-005 on 3rd October 2020 and Autocad LT 2021 stopped working. Have since tried clean installation of the current Autocad LT 2021 download, updating license manger etc with no success. This is causing real issues for me, I'm a sole practitioner Architect relying on Autocad LT to operate my business. Anyone in same boat or solved this?
Etiquetas (4)
maxim_k
en respuesta a: Anonymous
Welcome to Autodesk Forums!
Hi Bruce,
What macOS do you have on your Mac?
Is it Mojave?
I have found this article:
https://mrmacintosh.com/mojave-2020-005-security-update-causing-major-problems-updated/
Maybe it could explain the issues with AutoCAD for Mac too.
BTW, have you installed the last AutoCAD LT 2021 Update?
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
pendean
You need to be logging a support request at your Account page while you wait, these forums are peer support for the most part, here is the link https://knowledge.autodesk.com/contact-support
en respuesta a: maxim_k
Thanks, will have a look at this - has happened to two similar specced macs, both running high sierra OSX and both updated with the security fix so looks like it is systematic.
en respuesta a: pendean
Thanks I'll do that, it has happened to two similar specced macs, both running high sierra OSX and both updated with the security fix so looks like it is systematic, want to make sure others see it before upgrading the OSX.
maxim_k
In any case you need to have Time Machine backup or any other type of whole system backup before applying update.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Yes, seems there might be a feasible solution in rolling back the update but keen that it doesn't open the system up to security issues by doing so.
maxim_k
@Anonymous
BTW - what does it mean? What happens after you trying to launch AutoCAD?
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
 The icon bounces about as it normally would if getting ready to launch (if I right click it says application not responding), it keeps bouncing and then stops bouncing. No error message at all. The startup splash screen appears for a few seconds and just disappears, no error message.
maxim_k
Have you tried another user account on your Mac?
Do you see some sing special in Console.app, when you launch AutoCAD?
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Fixed by Autodesk technical call who uninstalled 2021.1 and reinstalled 2021.0, apparently some glitch with 2020.1 working with High Sierra OSX. Been advised not to apply the latest 2021.1 fixes.
Will probably look at upgrading my machine and OS soon, it's  a 10 year old machine and although heavily upgraded, powerful and perfectly fine, the hardware will no longer be supported by Apple on their new operating systems.
Thanks for your help / ideas.
