GKPByDesign
366 Vistas, 1 Respuesta
Printing from PDF some wipeouts and curved hatch appear solid black
Now this is starting to get irritating, I have tried multiple plot configurations, ive tried different quality levels, ive tried unticking layer items. And after searching on forums I cannot find a solution.
I shouldn't need to buy another PC3 plot configuration, I should be able to print these natively from AutoCAD, any solution ?
maxim_k
en respuesta a: GKPByDesign
Hi @GKPByDesign
Do you have transparency assigned to that objects and you print with transparency enabled.
If yes and you print PDF from Preview app, then try to print from Adobe Acrobat.
Do you see the difference?
Can you also share the drawing itself (or part of it) here?
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
