maxim_k
en respuesta a: jtribbey72
>>>>> What should I be looking for in the annotation scale list?
SCALELISTEDIT command:
https://help.autodesk.com/view/ACDMAC/2021/ENU/index.html?guid=GUID-52B8B084-1DE0-403F-957B-EADD0856...
Do you see something strange / unusual in the Drawing scale list?
You can also verify supported scales for the selected annotative object:
- active viewport with problem dimension
- select dimension, right-click and select:
You should see Annotation Object Scale List Dialog Box:
https://help.autodesk.com/view/ACDMAC/2021/ENU/index.html?guid=GUID-1E3DCBD5-C0F1-4598-9408-B330636E...
Is everything all right there?
You can edit - delete or add annotation scales for selected object in this dialog.
Can you share your problem drawing (or part of it) here? I can look at it.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
