1353 Vistas, 11 Respuestas
Help needed for problem with xref not refreshing
Can anyone help with a problem that I am having with xref refreshing?  The problem has to do with when the original xref file for the main plan is changed, it does not reload while the window is open and there is a yellow triangle with an exclamation mark that appears.  The only way to see the original xref file in the plan is to close the window and reopen in.  Normally it changes immediately when you go to the other window, but new issue has been happening more often.  Can anyone help with this problem?  I have included a screen video.  Thanks for the help!
Etiquetas (1)
Etiquetas (1)
