office6PUWT
349 Vistas, 2 Respuestas
not able to use UNION tool
I've attached a 3D dwg file made up of a surface and a solid, for some reason I'm unable to convert the surface into a solid or make them into a single object? Can anyone advise on why this might be please?
Luke
imadHabash
en respuesta a: office6PUWT
There must be no gaps between the surfaces. i have this message '' Solid creation failed, no watertight volume detected. '' !!! also i get '' surface cannot be thickened with specified value. Object intersects itself. ''
try to fix this errors to get what you need .
Imad Habash
office6PUWT
en respuesta a: imadHabash
Is there a single command I can use to fill any gaps in the geometry and make the surface watertight? Or one perhaps to isolate the problem areas? Also what does it mean when an object intersects itself? Does this refer to the top and bottom parts of the dwg or just the problem surface nut bit?
all best
Luke
