439 Vistas, 1 Respuesta
Customise temporary override keys
I would like to create custom hotkeys for when I need to object snap, I almost always have my snaps off.
e.g. Ctrl + 1 for endpoint, Ctrl + 2 for intersection, Ctrl + 3 for midpoints etc.
Is there anyway this can be customised? I have the .cuix file from my Windows PC, but I understand that this cannot be imported into my Mac. I am using Autocad 2019.
Thank you.
Etiquetas (5)
maxim_k
en respuesta a: Anonymous
Welcome to Autodesk Forums!
Hi Morris,
There is no official way to customize temporary override keys on Mac.
Are you sure you can use Ctrl+1, Ctrl+2, etc. temporary overrides in AutoCAD for Windows?
AFAIK you can use only Shift+(some key) for creating temporary overrides, but not Ctrl+(some key).
Temporary overrides for AutoCAD for Mac are inside
/Applications/Autodesk/AutoCAD 2019/AutoCAD 2019.app/Contents/Resources/OverrideRoot.cui
file. Temporary overrides for END, INT and MID OSNAPs already defined in this file and they are the same as in AutoCAD for Windows:
https://knowledge.autodesk.com/support/autocad-lt/learn-explore/caas/CloudHelp/cloudhelp/2019/ENU/Au...
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
