davidyPLERR
482 Vistas, 1 Respuesta
Draw a 1mm thick line
I would like to draw a line that is 1mm thick and stays 1mm thick in model space when the zoom changes. Where do I start?
maxim_k
en respuesta a: davidyPLERR
Welcome to Autodesk Forums!
Hi David,
You can use PLINE command to create polyline object and assign it 1 mm (unit) width during creation- use width option after you pick the first point:
http://help.autodesk.com/view/ACD/2021/ENU/?guid=GUID-11883C70-6435-4F80-8FB4-F6E933B8FD94
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
