en respuesta a: pendean
I'm picking up on this old thread as I still can't find a solution to this problem. I want to be able to 'VP Freeze' a layer in all viewports except the current one, which can easily be done on Windows but the functionality appears to be missing on Mac.
The link quoted in the original question on this thread is to an article which says at the bottom " Create New Layers That Are Frozen in All Layout Viewports" (which is exactly what I want to do) but there is no explanation on how to actually do it. It then says "This is a shortcut..." but there is no link or shortcut to another article.
A bit more searching and I found another article (https://knowledge.autodesk.com/support/autocad-for-mac/learn-explore/caas/CloudHelp/cloudhelp/2021/E...) which says it is for AutoCAD Mac but then outlines the Windows process. I do not have the "VP Freeze" menu item when I right-click a layer in Mac. Just in case this is the issue, I am using AutoCAD LT on Mac but there isn't a forum available for that so I thought this was the best place to post the questions. It is functionality that is missing on AutoCAD LT on Mac but available on AutoCAD Mac and AutoCAD LT on Windows?
This is something that I need on an almost weekly basis for the work that I do and since working from home (on a mac) I am having to get someone else in the office to do this task to save time (some of our drawings can have 30+ layouts). Any Mac workaround would be very gratefully appreciated!
