- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
I copied the wrong code
Sorry, this is the code:
(defun c:escadas()
(setq 2dpontos (getvar "osmode"))
(setq 3dpontos (getvar "3dosmode"))
(setvar "3dosmode" 0))
;indicar pontos
(setvar "osmode" 1)
(setq p1 (getpoint "\nIndique o ponto de inserção: "))
(setq p2 (getpoint "\nIndique o segundo ponto: "))
(setq largura (getdist "\nIndique a largura das escadas: "))
;sobre a viga
(setvar "osmode" 1)
(setq p4 altura (getdist "\nIndique a altura da viga: "))
(setq p5 espessura (getdist "\nIndique a espessura da viga: "))
(setvar "osmode" 0)
(setq medida1 (/ p4 (sin ( angle p1 p2))))
(setq medida2 (+ ((angle p1 p2) (angle p2 p1) 90) = 180))
(command "pline")
p2 (angel p1 p2) (distance ( * cos(angle p4) distance p5 p2)
(setvar "3dosmode" 3dpontos)
(setvar "osmode" 2dpontos)
; converts radians to degrees
(defun RtD (r) (* 180.0 (/ r pi)))
; converts degrees to radians
(defun DtR (d) (* pi (/ d 180.0)))
