maxim_k
en respuesta a: Anonymous
Hi @Anonymous,
The code you attached shows another error, when I try to use it in AutoCAD:
"too few arguments in SETQ: (SETQ P4 ALTURA (GETDIST "\nIndique a altura da viga: "))"
and it is really true:
The statement (SETQ P4 ALTURA (GETDIST "\nIndique a altura da viga: ")) in this routine doesn't assign anything to P4 variable - there should be something between P4 and ALTURA variables: some GET function or some already assigned variable.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
