450 Vistas, 3 Respuestas
06-11-2020
04:28 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
06-11-2020
04:28 AM
Error: syntax error
Hi Guys ! I want to run a AutoLISP app in AutoCAD. I am on a Mac. It is possible to run but then while performing it shows an error message saying: " error: syntax error".
The code is in the attachments.
Please help !
06-11-2020
05:46 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
06-11-2020
05:46 AM
Hi @Anonymous,
The code you attached shows another error, when I try to use it in AutoCAD:
"too few arguments in SETQ: (SETQ P4 ALTURA (GETDIST "\nIndique a altura da viga: "))"
and it is really true:
The statement (SETQ P4 ALTURA (GETDIST "\nIndique a altura da viga: ")) in this routine doesn't assign anything to P4 variable - there should be something between P4 and ALTURA variables: some GET function or some already assigned variable.
Maxim Kanaev
Architect
MARSS
Maxim Kanaev
Architect
MARSS
06-11-2020
06:08 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
06-11-2020
06:08 AM
should it work if i insert (setq p4 (getdist "\nIndique a altura da viga: ")) instead of (setq p4 altura (getdist "\nIndique a altura da viga: ")) ?
06-11-2020
06:39 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
06-11-2020
06:39 AM
Yes, if the subsequent part of the code is correct.
But (+ ((angle p1 p2) (angle p2 p1) 90) = 180)) seems to be incorrect, because "= (equal to)" also is a function and its signature is (= numstr [numstr ...]. In your case, you are using it incorrectly.
The syntax of "+" function is also incorrect, it should be (+ [number number ...]), but you have something strange.
Maxim Kanaev
Architect
MARSS
Maxim Kanaev
Architect
MARSS
