364 Vistas, 3 Respuestas
Error: syntax error
Hi Guys !
I want to run a AutoLISP app in AutoCAD.  I am on a Mac. It is possible to run but when i perform the "\nIndique o segundo ponto: "
it shows an error message saying: " error: syntax error".
Here is the code:
(defun c:escada()
    (setq pontoS (getvar "osmode"))
(setq pontoS3d (getvar "3dosmode"))
(setvar "3dosmode" 0))
;obter pontos
(setvar "osmode" 1)
(setq p1 (getpoint "\nIndique o ponto inserção: "))
(setq largura (getreal "\nIndique o ponto da largura: "))
(setq espelho (getreal "\nIndique o espelho: "))
(setq cobertor (getreal "\nIndique o cobertor: "))
(setq ndegraus (getint "\n Indique o numero de degraus: " ))
  (command "ucs" p1 "" )
  (setq p1 (trans p1 0 1))
 (command "box" p1 (list largura cobertor espelho))
 (command "ucs" "world")
;repeticao degraus
 (repeat ndegraus
  (command "copy" "last" "" p1 (list 0 cobertor espelho))
Please somebody help me !
maxim_k
en respuesta a: Anonymous
Hi @Anonymous,
>>>>>It is possible to run but when i perform the "\nIndique o segundo ponto: " it shows an error message saying: " error: syntax error".
Sorry, but there is no "\nIndique o segundo ponto: " in the code you provided and it seems to work correctly on my side.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
en respuesta a: maxim_k
 I copied the wrong code
Sorry, this is the code:
(defun c:escadas()
(setq 2dpontos (getvar "osmode"))
(setq 3dpontos (getvar "3dosmode"))
;indicar pontos
(setvar "osmode" 1)
(setq p1 (getpoint "\nIndique o ponto de inserção: "))
(setq p2 (getpoint "\nIndique o segundo ponto: "))
(setq largura (getdist "\nIndique a largura das escadas: "))
;sobre a viga
(setvar "osmode" 1)
(setq p4 altura (getdist "\nIndique a altura da viga: "))
(setq p5 espessura (getdist "\nIndique a espessura da viga: "))
(setvar "osmode" 0)
(setq medida1 (/ p4 (sin ( angle p1 p2))))
(setq medida2 (+ ((angle p1 p2) (angle p2 p1) 90) = 180))
(command "pline")
p2 (angel p1 p2) (distance ( * cos(angle p4) distance p5 p2)
(setvar "3dosmode" 3dpontos)
(setvar "osmode" 2dpontos)
; converts radians to degrees
(defun RtD (r) (* 180.0 (/ r pi)))
; converts degrees to radians
(defun DtR (d) (* pi (/ d 180.0)))
maxim_k
OK, actually you double posted.
The answer related to that question is here:
https://forums.autodesk.com/t5/autocad-for-mac-forum/error-syntax-error/m-p/9574196#M38591
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
