05-30-2020
12:59 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
05-30-2020
12:59 AM
I reviewed your drawing and have fount that there are a lot of parametric constraints in it:
Do you really need them?
In the attached drawing I deleted them all with menu Tools -> Parametric ->Delete Constraints
Command: _DelConstraint
All constraints will be removed from selected objects…
Select objects: all
75075 found
Select objects:
2268 constraint(s) removed
I think they were created because you have Infer Constraints turned ON.
Check CONSTRAINTINFER system variable and set it to 0 (zero) if you don't need constraints. You may accidentally turned it ON with a button on Status Bar:
So be careful with it.
Maxim Kanaev
Architect
MARSS
