maxim_k
en respuesta a: Anonymous
Hi Dale,
>>>>>I would like to chamfer around the top edge, front and back, and down 1 inch on the side as indicated by the dimension.
If you want to chamfer only part of the detail, you can slice it in two parts with SLICE command, create chamfer on the edges you need, then use UNION command to combine two parts.
See attached drawing.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
