682 Vistas, 9 Respuestas
05-24-2020
08:42 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
05-24-2020
08:42 AM
I worked on the draw (11.5M) and suddenly it becomes very slow. I tried to copy to new draw, purge, -purge,recover but nothing helps.
Please help.
Thanks.
¡Resuelto! Ir a solución.
05-24-2020
09:51 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
05-24-2020
09:51 AM
Hi Marta,
What AutoCAD version do you use?
If it is 2020 or 2021 version, I recommend you to clear all blocks from Recent blocks tab of Blocks palette:
Activate Blocks palette, go to Recent block tab, right-click inside the tab and select "Clear all" from context menu.
Test AutoCAD performance.
Maxim Kanaev
Architect
MARSS
Maxim Kanaev
Architect
MARSS
05-30-2020
12:07 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
05-30-2020
12:07 AM
Do you have slow performance only with one particular drawing?
If so, can you share it here on the Forum?
Maxim Kanaev
Architect
MARSS
Maxim Kanaev
Architect
MARSS
05-30-2020
12:18 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
05-30-2020
12:18 AM
It was 11 M and after very small changes became 15M.
I added the file.
Thank you.
05-30-2020
12:59 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
05-30-2020
12:59 AM
I reviewed your drawing and have fount that there are a lot of parametric constraints in it:
Do you really need them?
In the attached drawing I deleted them all with menu Tools -> Parametric ->Delete Constraints
Command: _DelConstraint
All constraints will be removed from selected objects…
Select objects: all
75075 found
Select objects:
2268 constraint(s) removed
I think they were created because you have Infer Constraints turned ON.
Check CONSTRAINTINFER system variable and set it to 0 (zero) if you don't need constraints. You may accidentally turned it ON with a button on Status Bar:
So be careful with it.
Maxim Kanaev
Architect
MARSS
05-30-2020
12:36 PM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
05-30-2020
12:36 PM
I gave you instructions specifically for the Mac.
Maxim Kanaev
Architect
MARSS
Maxim Kanaev
Architect
MARSS
