- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
Dimensions
Hi there,
When I use the rectangle to dimension a room, it doesn't give me the size what I want and when I do offset the same thing. Could you please help me with that?
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Hi Morteza,
Can you illustrate somehow the problem?
Do you mean you are drawing a rectangle and its dimensions don't match the distances you want?
Offset of what?
Maxim Kanaev
Architect
MARSS
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Thank you for your reply.
Do you mean you are drawing a rectangle and its dimensions don't match the distances you want? Yes.
Offset of what? Offset of walls, door frames and etc.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Maxim Kanaev
Architect
MARSS
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Dimensions.
When I'm drawing a rectangle and its dimensions don't match the distances I want.
And when I do offset walls, door frames and etc. don't match either the distances I want.
Thanks.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Maxim Kanaev
Architect
MARSS
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Please find screen recorded, for dimensions.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
when you type "2000,2000" AutoCAD takes this as absolute coordinates and puts the opposite corner of the rectangle at coordinates x = 2000 y = 2000 of current coordinate system.
You should use in this case relative coordinate input and type @Anonymous,2000 when AutoCAD asks for other corner.
Not sure about offset - it should work correctly.
Can you attach drawing with wrong offset results?
Maxim Kanaev
Architect
MARSS
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Could you please do a screen recording and guide me how can I do the rectangle at coordinates x = 2000 y = 2000 of current coordinate system? Or we can do screen share from TeamViewer!
I think once we solve this problem then offset should works properly.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Here it is:
Maxim Kanaev
Architect
MARSS
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Hi there,
Please watch the video I did a screen record, I would like to type dimensions the same as that not in the command section.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Now you show dimension input with Dynamic input turned on.
You can turn on Dynamic input on the Status Bar with this button:
Another way to toggle Dynamic input is with Shifr+Cmd+D shortcut or with F12 (Fn+F12) function key.
As soon as you turn on dynamic input, you can draw rectangle with method you showed in your screen recording -
you will see dimension input in the drawing area.
Maxim Kanaev
Architect
MARSS
