maxim_k
en respuesta a: jenaleetsimara
When Title block is a separate block inside drawing you cannot insert it directly with INSERT command.
You can add the drawing with Title block to Block Libraries tab of Blocks palette. You just need add this drawing to library as "Drawing with multiple blocks":
Then you will be able to insert Title block directly from Blocks palette.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
