- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
I have two issues which I can't seem to fix.
Dear Forum
1. I've updated to AutoCAD LT 2020 and now when I use, for example, Pedit and other commands with follow up choices I don't get get a white multiple choice box which was floating, instead I have just the old fashioned command line at the bottom which is in small text and not easy to see the choices. The also applies to the offset command, when I used to get a floating box for inputting the offset dimension now nothing just shows in the command line.
2. When I draw a line I used to get information about what angle it is being drawn at but now there's nothing.
Perhaps theres a setting in preferences which would fix these issues?
I hope you can help with these two queries.
Kind regards
George Gibson
¡Resuelto! Ir a solución.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
1. What is DYNMODE set to? Try 3
2. See #1
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Thanks for the reply and solution. dynamic Input setting needed adjusted.
Cheers for your help.
Regards
George
