04-10-2020
06:32 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
04-10-2020
06:32 AM
>>>>I am still unable to replicate the results.
Do you mean you cannot subtract inner rectangles from the "plate"?
Are you using SUBTRACT command correctly?
When you start command, you need to pick an object from which you want to subtract ("plate" in this case), then you need to hit Return, then AutoCAD asks to select objects you want to subtract - now you select all inner rectangles, then hit Return. Rectangles should be subtracted from "plate".
Maxim Kanaev
Architect
MARSS
Maxim Kanaev
Architect
MARSS
