GKPByDesign
4311 Vistas, 17 Respuestas
Autocad 2021 - Having to regen all the time - graphic error
Having a graphic error with all my files, if I remove a line, or add a hatch, or update an xref, it leaves behind low poly versions of what ive deleted or the action ive done. If I regen it will disappear, but its getting quite distracting now ! Can some one help
pendean
en respuesta a: GKPByDesign
Which MAC hardware are you on, and what is your MAC OS?
GKPByDesign
en respuesta a: pendean
MacBook Pro 16inch I9 8 Core
Catalina 10.15.4
GKPByDesign
Back to 2020 I go!
maxim_k
Having MacBook Pro 16-inch (i7 model) Catalina 10.15.3, but don't see such problem.
Do you use external monitor?
Have you tried to switch to "Open GL Core Profile" in Graphics Engine settings in AutoCAD Preferences?
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
wei503
We have seen this issue on some specific mac models starting from macOS 10.15.4. It is likely to be graphics driver issue with Metal engine, and we are researching what we can do to fix it, or we have to escalate to Apple for a fix in the graphics driver in next OS update.
You can use the workaround below, to switch to OpenGL engine:
Click menu AutoCAD 2021 > preferences > in General tab, change the graphics engine from Metal to OpenGL. Then restart AutoCAD. The issue should be gone.
Wei Ma
AutoCAD QA Manager
en respuesta a: wei503
worked perfectly! thank you!
marty8681
Any news on this issue as I still have it.
MacBook Pro 16in i9 8 core (MacbookPro16,1)
MacOS 10.15.5
AutoCAD 2021 LT 2021.0.1
R.46.M.1761
wei503
en respuesta a: marty8681
@marty8681 , please try the workaround I posted above.
Wei Ma
AutoCAD QA Manager
I still have the same problem even after changing it from metal to openGL
maxim_k
en respuesta a: Anonymous
Welcome to Autodesk Forums!
Hi @Anonymous,
Have you relaunched AutoCAD after you changed settings?
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
en respuesta a: maxim_k
I did its still showing some places.
maxim_k
Not sure why you still have such issues. After I changed Graphics Engine to OpenGL Core Profile I don't have any issues on my side.
What Mac model do you have? What macOS version do you have on your Mac?
Can you share screenshot of what you see in the drawing area?
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Jay_Cad_LA
Helped me as well!
Thanks a bunch : )
housecandy
housecandy
I just bought a new MacBook Pro and having the same issues. I changed the Graphics Engine to OpenGL, restarted and still happening.  They disappear once I zoom in or out.
maxim_k
en respuesta a: housecandy
Hi @housecandy,
Have you installed >>>>this<<<< Update?
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
JammieSeepaul
Verified!
Thank you
