maxim_k
en respuesta a: Anonymous
Hi Kael,
Look at the attached drawing.
What I have done to prepare for using PRESSPULL:
- created separate layer for blocks and moved them all to that layerr, turned it off temporary
- created separate layer for text and moved all text objects to that layer, turned it off temporary
- used OVERKILL command to clean drawing (the part of the drawing which now is visible). OVERKILL has found:
140 duplicate(s) and deleted them, 150 overlapping object(s) or segment(s) and deleted them
So now you can try to use PRESSPULL command. In most cases it works fine on my side. There are some areas in the drawing which are not closed, so you also need to verify them.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
