03-27-2020
07:30 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
03-27-2020
07:30 AM
I thought you need everything aligned to the right, but you need only two of them....
I see you save your drawings in 2010 DWG format for some reason.
What AutoCAD version you are using?
If it is 2018 or later, you need to use 2018 DWG file format for save (see right side of General tab of AutoCAD Preferences) in order not to allow attributes to shift from correct position between opening drawings.
I attached drawing saved in 2018 DWG format. Try to set default format for save to 2018 DWG
Then open attached drawing, work with it, save, close, reopen and look at the attributes.
Maxim Kanaev
Architect
MARSS
