622 Vistas, 3 Respuestas
Scripts not available in Autocad for Mac but fine in Autocad
In Autocad 2020 for Mac, I have students trying to run a script (.scr) and they cannot select the script once they type the SCRIPT command. The script file shows grey in their section window.
This works fine in Autocad 2020 on a PC.
Any ideas?
Etiquetas (1)
maxim_k
en respuesta a: Anonymous
Welcome to Autodesk Forums!
Hi Stephen,
I don't have such issue on my side.
 In AutoCAD for Mac I use the same command for loading and executing scripts as in AC for PC.
After I call SCRIPT command, standard file selection window appears with .scr file format filter and I can select .scr file in it:
Yes, I have to say that in macOS Mojave and Catalina sometimes files matching filter are grayed out in such dialogs. Not sure is it a bug in AutoCAD or in macOS, but you still can select them in relevant dialogs for opening.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Leaf.chai
Hi Stephen,
Can you share the script file you meet the error?
I guess it may related to the file path or something which related to the OS difference.
Leaf
Leaf Chai
AutoCAD QA Analyst
en respuesta a: Leaf.chai
Seems the renaming process used by the student(s) was scriptname.txt to scriptname.scr ... but ... ended up as scriptname.scr.txt ...
