785 Vistas, 10 Respuestas
OBJECTS SNAP TO DIFFERENT AXIS
I have moved the UCS, and am able to draw my first two rectangles as I expect, on what is now the XY plane.  However, after that, the rectangles will only go in the YZ plane, and I can't figure out how to get them to draw on the XY plane.  I can copy the original rectangles and manipulate them to the correct shape and location, but obviously this is a lot more tedious.  Any advice?  Using AutoCAD 2018 for MAC.
Etiquetas (1)
pendean
en respuesta a: Anonymous
You also have to set PLAN command to match the UCS you wish to draw in 2D.
HTH
en respuesta a: pendean
Doesn't seem to fix the issue.  I am also encountering an issue where I can't turn a rectangle into a region.  I'm trying to follow along with a tutorial, and just can't seem to make these things work.  I don't know what I'm missing.
Patchy
Are the lines all touching one another?
Post your drawing, let's see.
pendean
REGION command converts closed Plines into regions just fine for all of us. Share your DWG file with us if you can.
The dedicated MAC forum is over here in case we stumble across a solution you still cannot replicate https://forums.autodesk.com/t5/autocad-for-mac/ct-p/4051
en respuesta a: Patchy
I'm drawing it as a rectangle, so I should think it would
Thanks!
Patchy
Can you save it to 2007 format? this one crashed my autocad ☺
Here ya go
Patchy
Show me which part that you want to turn into Region, because I drew rec. and have no problem turned them into regions.
maxim_k
Hi Amanda,
You not only moved UCS in your drawing, but also rotated it in 3D. So the XY plane of the current UCS is perpendicular to YZ plane of WCS - that is why you can draw rectangles only in "vertical" position.
I also don't have any problems with REGION command, it creates regions from any of closed polylines in your drawing. Can you show which polyline you cannot to convert?
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
