02-01-2020
03:37 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
02-01-2020
03:37 AM
Hi Zak,
>>>>Didn't try to update to Mojave.
Don't update to Mojave as 2013 version will not run at all! It is not supported on Mojave.
Your drawing file was marked as "Read only" because of AutoCAD's crash.
Find it in Finder and use "Get info" from context menu and very if the file is locked (read only). If it is not locked, then you may try to duplicate it in Finder (context menu -> Duplicate) and open this copy.
Or you can open file as "read only" and then use SAVEAS command to save it under another name. Once it will be saved, you will be able under new name to edit it.
Maxim Kanaev
Architect
MARSS
Maxim Kanaev
Architect
MARSS
