UNKNOWN.DESIGN.LAB
en respuesta a: maxim_k
Hello @maxim_k , appreciate the links. Trying "Rename" Command on a Minotti Sofa DWG [1] and another Chair DWG [2] showed both files do share identical group names for different furniture pieces. Also testing to pinpoint the error cause showed the issue seems to be with my working DWG; New DWGs receive blocks from files 1&2 normally. Clues to why blocks mix and transfer incorrect with the working DWG but carry as should to a new one?
I attached the working DWG & 2 example Minotti furniture block files for clues. This issue is recurring & often prevents using manufacturers models in my work DWGs – Support to resolve is appreciated!
