430 Vistas, 5 Respuestas
Mac Update 10.15.2 installed and X-Ref paths not loading & cannot be deleted
Macbook has just auto-insatlled OS10.15.2 and running ACAD 2019 for Mac.
Since the OS update has been installed, files open with x-ref paths unreadable / unallocated. The missing x-refs cannot be re-linked, as the drop down menus & buttons to do so are ghosted. The missing x-refs cannot be deleted either.
Help is much needed and will be greatly appreciated.
pendean
en respuesta a: Anonymous
A search of the dedicated AutoCAD for MAC forum came up with many solutions, here is the most common fix https://forums.autodesk.com/t5/autocad-for-mac-forum/autocad-for-mac-2019-support-for-macos-catalina...
AutoCAD fort MAC forum is over here for your future queries https://forums.autodesk.com/t5/autocad-for-mac/ct-p/4051
HTH
maxim_k
Hi Jacqui Alexander,
Have you installed this update:
https://knowledge.autodesk.com/support/autocad-for-mac/downloads/caas/downloads/content/autocad-for-...
before upgrading macOS to Catalina?
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
en respuesta a: maxim_k
Hi Maxim_K,
Thanks for your response.
ACAD V2019.1 was already installed prior to the Mac OS update.
en respuesta a: pendean
Hi Pendean - thanks for your response.
I have now posted the topic on the acad-mac forum. I have double checked and acad2019.1 was installed prior to the Catalina update.
Hopefully there is another solution.
maxim_k
Do you have this problem only with one drawing? Or it affects all drawings?
Where are external references? On local drive or somewhere on network drive?
Can you attach screenshot of Reference Manager palette with one of x-refs selected? Which drop-down (button) is grayed out on it?
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
