steven-g
en respuesta a: Anonymous
That's certainly not an option in Autocad LT (windows), that's part of the dataextraction command in full Autocad, so I doubt it is available for Mac, the closest you get in LT is the attext command which will work with blocks that have an attribute and can extract information from block attributes, this needs an attribute extraction template (simple text file), but even that would only get you part way, it will extract the information but you still have to manually do any sorting and counting of the information. LT has no automation for that.
