426 Vistas, 4 Respuestas
I can't modify a 3d model from fusion 360 in Autocad neither export to Model
Hi, could you help me?, I am having problems with a sheet on Autocad, I exported a 3d model from Fusion 360 to Autocad, but I can't export the drawings to Model window on Autocad, I only can move the drawings through the sheet window, but I can't neither copy to Model window nor modify. what is the problem ?
pendean
en respuesta a: Anonymous
That's how fusion360 export work.
Ask in the Fusion360 forum what other options you might have in that software https://forums.autodesk.com/t5/fusion-360/ct-p/1234
maxim_k
Hi Alfredo,
Can you describe in more details how did you export 3d model from Fusion 360?
Did you follow these instructions?
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
OP21
Might be a bit dated, but there's some good information in this thread concerning "export layout" in AutoCAD when dealing with a Fusion exported dwg.
https://forums.autodesk.com/t5/fusion-360-design-validate/how-to-export-fusion-360-drawing-files-int...
Hope this helps!
Omar
P.S. If this did help you, remember to "Accept as Solution", so the answer can help others. "LIKES" are always welcomed and much appreciated! Thank-you.
maxim_k
en respuesta a: OP21
This thread is about export layout method, but:
1/ There is no EXPORTLAYOUT command in AC for Mac.
2/ Seems OP needs 3D model, but when you export layout to model, you will get 2D view of 3D model.
To export full 3D model from Fusion to AutoCAD, one have to export Fusion model as a STEP or IGES file, then import to AutpCAD, but again - AutoCAD for Mac cannot import STEP or IGES files. So looks like OP needs some additional conversion software which can convert STEP or IGES to DWG (on Mac it can be Rhinoceros)
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
