UNKNOWN.DESIGN.LAB
1148 Vistas, 2 Respuestas
Transparency not working.
Hi Forum, Transparency is not working for some reason. I try setting through hatch dialogue box or layer transparency to no result. Is there anything I have to turn on to view transparency?
maxim_k
en respuesta a: UNKNOWN.DESIGN.LAB
Where you cannot see transparency?
If - in the drawing area, then verify that "Show/Hide Transparency" button on Status Bar is turned on (System Variable TRANSPARENCYDISPLAY=1)
If you don't see transparency when you print (save to PDF), then verify text you checked "Print transparency" option in Print window.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
UNKNOWN.DESIGN.LAB
en respuesta a: maxim_k
Thanks @maxim_k. Wiz!
