554 Vistas, 2 Respuestas
PNG Import Weirdness
Trying to import a .png file for my logo and I'm not understanding the result.
Using 2019 AutoCAD LT for Mac.  Go to FILE/ATTACH.  Choose the .png.  I don't change any of the settings.
This is the original file:
this is what imports:
Not sure where to even start looking for an answer on this.  I can load the .png into my image editor fine.  Is .png import even possible?
maxim_k
en respuesta a: Anonymous
Welcome to Autodesk Forums!
Hi Keith,
Select the image, you attached, in the drawing area, then in Properties Inspector (with "ALL" properties active) go to "Misc" section (on the bottom" and check-mark "Background transparency" option.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Thanks!!!  That was about as easy as taking a breath...
