340 Vistas, 1 Respuesta
DWG to PDF
Hello everyone,
I'm having some problems with the publish option and I would like to try doing the publish with the "printer from page setup" option. The thing is, in my layouts, I always have the DWG to PDF printer but I usually then click at the bottom to do "Save as PDF". If I click "Print" a little printer pop-up appears on my bottom bar and nothing really happens after that. When I open this printer pop-up I have all the pending printing jobs and always the same message "Printing - the printer is in use" and no job ever gets completed....
How can I fix this error? I would really love to try and publish print all my layouts in order to try and solve some printing issues that are coming up with the standard print to pdf publish option...
maxim_k
en respuesta a: Anonymous
Hi Ana Rita,
What AutoCAD version are you using and what macOS installed on your Mac.
Are you sure that "DWG to PDF" printing device is compatible with macOS you have on your Mac? And what kind of printer is this "DWG to PDF"? Please elaborate.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
