maxim_k
en respuesta a: Anonymous
Hi Nathan,
Do you want to import Page Setups? If yes, you can try to import them with Page Setup Manager - menu File -> Page Setup Manager, then use "gear" menu under page setup list and select "Import", then select drawing with page setup(s) you cerated in Draftsight.
>>>>>Also, my print options do not display Acrobat DC as a pdf printer despite it being installed. Any ideas?
AutoCAD should show printing device if it is installed in Printers & Scanners pane of macOS System Preferences. Do you have Acrobat DC in System Prefs as one of the printers installed on your Mac?
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
