- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
I'm working on autocad for mac 2020. I have approx 65 page layouts that need to be re-arranged. Dragging them one by one across the ribbon bar at the bottom seems to be the only solution I can find, which is painful. I can only view 9 layout tabs across the bottom of my screen at a time, so dragging over is a mult-step process. Is there a way I can view all of my layout tabs in a list and rearrange them there??
Thanks!
Roxanne
¡Resuelto! Ir a solución.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Hi Roxanne,
Have you tried QUICKVIEW command:
You can drag layouts inside QUICKVIEW window:
Maxim Kanaev
Architect
MARSS
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
THANK-YOU Maxim!! A much easier task ahead of me now. Appreciate your time!
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Just like Maxim said, QVIEW palette can solve this issue:
1. Run OVIEW command.
2. Drag and drop the Layout you want to re-arrange.
In QVIEW palette, you can also multi-select layouts by HOLD SHIFT or CMD key to select. Then you can multi-delete them. Multi re-arrange is not supported now.
Leaf
AutoCAD Test Engineer
Leaf Chai
AutoCAD QA Analyst
