340 Vistas, 2 Respuestas
How do I actually use the TRIAL
This is a simple question... How do I actually get to use the software. So far I have been unable to get past the Forum. I contacted Service support and they referred me to the FORUM. Please can somebody tell me how I actually get to use the software.
maxim_k
en respuesta a: Anonymous
Welcome to Autodesk Forums!
Hi Kenneth,
It is not so difficult.
You can find all instructions here:
https://knowledge.autodesk.com/customer-service/download-install/install-software/free-trial-install...
Trial download page is here:
https://www.autodesk.com/products/autocad/free-trial#
You need to select "AutoCAD for Mac" on the first popup window after you pick on red "DOWNLOAD FREE TRIAL" button, then follow instructions.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
maxim_k
After you start using Trial version, each time you launch AutoCAD, you will get an alert about Trial software. You should select "Use trial" and continue to use application.
You will have 30 days to test. The Trial version has the full functionality of a commercial application.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
