en respuesta a: pendean
@pendean wrote:
Is there an error message at the commandline?
Is it on a Locked layer perhaps?
Or is this an object dependent on other layers (or layer zero) to be thawed and unlocked?
When I enter the command it says select object on layer to merge or [Name/Undo] and I try to select an object so I hover over it and a shadow appears behind it but when I click on it nothing happens, no prompts come up and the command line is exactly where it was before I clicked. I checked the layers and none of them are locked and I can change each line individually but I figured there has to be a better way.
