- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
I using Autocad 2018 on Mac OS, But I don't know how to load lisp Command TL ( Measure distance) and Lisp Nam ( HVAC). Can you tell me a way to load them ?
¡Resuelto! Ir a solución.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Type in the command APPLOAD to load the lisp. Else you could drag and drop the lisp file into Autocad.
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Can you share both the lisp file so that I can see if it works on my system.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Ok. This is link to download file .lisp. You can try use it.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
I'm able to load the lisp in my system. After loading the lisp did you get the pop up like in the screen shot? and did the window show that the lt.lsp successfully loaded as shown in screenshot? If not the Lisp is not loaded. Try restarting the AutoCAD and see if it works. Though I am using windows I guess it should not look much different in mac.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
AutoLISP routine you tried uses VisualLISP, which is not supported in AutoCAD for Mac.
If you need AutoLISP routine for calculating total length of selected lines, polylines, arcs, circles etc., you can try this one:
https://forums.autodesk.com/t5/autocad-for-mac-forum/total-length-in-macos/m-p/8036223#M31675
It should work in AutoCAD for Mac.
Maxim Kanaev
Architect
MARSS
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
OK Thanks Maxcim ( Спасибо максим ). I had done. Can you tell me the way to load HVAC ( lisp draw pipe Flexible Air Duct) or Do you know what kind of lisp can draw it?
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
I'll look at it and will try to figure out the problem.
Maxim Kanaev
Architect
MARSS
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Hello bạn mình cũng đang có câu hỏi như bạn để có thể cài Lipnam trên mac os. Bạn đã làm được chưa nếu được chỉ mình được ko ?
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Hi @nguyentuananh.2t ,
Can you share Lisp routine you are trying to use on Mac?
Maxim Kanaev
Architect
MARSS
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
I can't load the HAVC lisp to draw the wind pipe in cad 2022 for mac
https://siscom.vn/huong-dan-tai-lisp-nam-moi-nhat-100-thanh-cong/
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Hi @thanhdatlc1982 ,
This application is only for AutoCAD for Windows, it has the installer which will run only on PC, plus I believe that it has Visual Lisp code which is not supported on Mac.
Maxim Kanaev
Architect
MARSS
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Hi @khamtiktok2 ,
@khamtiktok2 wrote:I want to batch print for macbook
Please look here:
https://help.autodesk.com/view/ACDMAC/2024/ENU/?guid=GUID-0D1DB83F-F1A3-4D22-8FBC-342B2E93172C
https://help.autodesk.com/view/ACDMAC/2024/ENU/?guid=GUID-BE4A9516-E037-44DB-B260-5EAF0230C749
https://help.autodesk.com/view/ACDMAC/2024/ENU/?guid=GUID-880C7D3B-D68F-4D95-B674-39A7D7BEA9A0
Maxim Kanaev
Architect
MARSS
