- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
I've looked and looked, but I'm at a loss as to why I can't reference files from a shared server. Can someone take a look at my server path mapping and tell me if I'm doing something obviously wrong? I've attached screenshots of both the finder path to the files I want to reference and the AutoCAD interface.
¡Resuelto! Ir a solución.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
FOUND AT section needs to be populated and match the line below it, "not found" should not be there too
Is the XREF saved with full path in the top file? That could be the problem, the program is still looking for that Y: drive location tat obviously works somewhere on some computer?
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Thanks for the reply!
Everything works on the other computer that uses these xrefs (a pc). My orphaned references match in "found at" and "saved path". The top file has a full path that checks out. It's just the parent files that have gone wrong: RC_00 and TB 364x48. I've attached two screenshots to illustrate.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Hi Kevin,
Your scenario works on my side correctly (AC 2019 on 10.14.5):
Can you verify once again:
does server path mapping assigned correctly?
Maxim Kanaev
Architect
MARSS
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
It's not matching; the "Found At:" field is blank and the "Saved Path:" field is correct. I think the problem is in the way I set up the Mac pathing; the Windows address seems to be fine. Is there a way to edit my Mac pathing? I only have 3 options and none of them work.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
It is not matching because path on windows side for some reason starts from Projects folder, which is inside homes/steveish/ssc-a folder on your "mothership3" server, but this Projects folder is not connected as volume on your Mac.
So you have to connect homes/steveish/ssc-a folder which is on "mothership3" server as separate volume on Mac. In Finder use menu Go->Connect to server and type path to server as follows:
smb://mothership3/homes/steveish/ssc-a - verify path, I could be wrong in spelling
or use Browse button to browse to ssc-a folder on server.
Then AutoCAD will be able to find Projects folder and and all subfolders.
Maxim Kanaev
Architect
MARSS
