maxim_k
en respuesta a: Anonymous
Welcome to Autodesk Forums!
Hi Lisa,
>>>>Is there a command that has replaced GATTE or something that is compatible on a Mac?
You can try to keep your Title Block as Xref, instead of block with attribute(s):
https://forums.autodesk.com/t5/autocad-for-mac-forum/gatte-command/td-p/8767968
Or you can try to use FIELDs for attributes: for example you can set default attribute value as current date field. If you add drawing(s) to Project, you can also use Custom Project properties as source for FIELDs in attributes inside block, then all you need is to change these custom properties in Project Manager palette and use REGEN to update FIELDs.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
