766 Vistas, 1 Respuesta
GATTE Command
Hi there,
I've recently switched to a Mac and am finding that a lot of commands that were usable on Windows, do not work on a Mac.
I used to be able to use the GATTE command to switch an attribute in my title block through out multiple layouts all at once. I don't want to have to go and change an attribute one by one when I have well over 20 layouts.
For example, I have 20 layouts and I need to change the date on all 20 to be the same but I don't want to have to go through each layout individually to do so.
Is there a command that has replaced GATTE or something that is compatible on a Mac?
Thank you!
