766 Vistas, 1 Respuesta
06-14-2019
02:05 PM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
06-14-2019
02:05 PM
GATTE Command
Hi there,
I've recently switched to a Mac and am finding that a lot of commands that were usable on Windows, do not work on a Mac.
I used to be able to use the GATTE command to switch an attribute in my title block through out multiple layouts all at once. I don't want to have to go and change an attribute one by one when I have well over 20 layouts.
For example, I have 20 layouts and I need to change the date on all 20 to be the same but I don't want to have to go through each layout individually to do so.
Is there a command that has replaced GATTE or something that is compatible on a Mac?
Thank you!
06-15-2019
02:51 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
06-15-2019
02:51 AM
Welcome to Autodesk Forums!
Hi Lisa,
You can try to keep your Title Block as Xref, instead of block with attribute(s):
https://forums.autodesk.com/t5/autocad-for-mac-forum/gatte-command/td-p/8767968
Or you can try to use FIELDs for attributes: for example you can set default attribute value as current date field. If you add drawing(s) to Project, you can also use Custom Project properties as source for FIELDs in attributes inside block, then all you need is to change these custom properties in Project Manager palette and use REGEN to update FIELDs.
Maxim Kanaev
Architect
MARSS
Hi Lisa,
Maxim Kanaev
Architect
MARSS
