- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
Hi there,
I have recently purchased a MAC and loaded ACAD 2018 Lt onto it (Previously using 2017 on a PC). When I import a picture (Jpegs or PNG files), the picture appears but if I close the ACAD application and re-open, it only shows me the pathway and not the image. I can confirm the pathway in a dialogue box as being correct and then the images re-show. Is there something I can switch on so that confirmation of the pathway is not required every time?
¡Resuelto! Ir a solución.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Where are (in what place - local folder or somewhere on network drive) the pictures you are trying to insert into the drawing?
What if you will place image files (pictures) to the same folder as your drawing?
Make a test - attach such image, save drawing, close and reopen it again.
Do you see the image in the drawing area?
Maxim Kanaev
Architect
MARSS
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
I have a work around but no solution as of yet. Please see my reply to the person who helped.
@Tiana_Y wrote:Hi @cal3SQEN ,
I'm just checking in to see if you need more help with this. Were you able to collect the information @maxim_k requested?
If so, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
What path settings do you use when you attach raster images?
Full, Relative or No path?
What path actually saved? (You can verify this in Xrefs Palette)
Maxim Kanaev
Architect
MARSS
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
It comes in under relative path by default on my programme so I have done a text with relative, full and no path. Bizarrely, anything coming in under Full or relative will now show as an image when you re-open the drawing (i.e. problem solved!) while no path will not. No idea what has changed to allow this to happen, but very happy that it has.
Thanks for all your help.
