06-10-2019
03:28 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
06-10-2019
03:28 AM
Hi
If I understand your description correctly, I believe that when you look at the properties of the Dimension in the 1st drawing, you will see "Rotated dimension" and in the 2-nd drawing it will be "Aligned dimension".
This should explain difference in Dimension behavior when you try to edit it with grips.
Maxim Kanaev
Architect
MARSS
Maxim Kanaev
Architect
MARSS
