maxim_k
en respuesta a: liyongfamily
You can set this crosshair color with this Terminal command:
defaults write ~/Library/Application\ Support/Autodesk/AutoCAD\ LT\ 2019\ Standalone/R23.0/local/HKCU_V1.plist "HKEY_CURRENT_USER.SOFTWARE.AUTODESK.AUTOCAD LT.PROFILES.<<UNNAMED PROFILE>>.DRAWING WINDOW.LAYOUTXHAIRPICKBOXETC" -int 8421504
To return back to original color:
defaults write ~/Library/Application\ Support/Autodesk/AutoCAD\ LT\ 2019\ Standalone/R23.0/local/HKCU_V1.plist "HKEY_CURRENT_USER.SOFTWARE.AUTODESK.AUTOCAD LT.PROFILES.<<UNNAMED PROFILE>>.DRAWING WINDOW.LAYOUTXHAIRPICKBOXETC" -int 0
You need to quit AutoCAD LT before executing these commands.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
