314 Vistas, 2 Respuestas
Can’t access Elevation Panel
I am using the student version of Autocad for Mac, 2019 and cannot find the elevation panel to draw elevation lines and do interior/exterior elevations.
All forums with suggestions talk about right clicking (doesn’t bring it up), changing profile (don’t see that option), using CUI (can’t find the elevation option)...so I am at a loss.
As of now, I’m restricted to top down floor plans and cannot progress any further. Is there a way to insert elevation lines with a command? Or better yet, a way to actually locate the Elevation Panel so I can add it to my screen?
Any help would be really appreciated. Thx
Etiquetas (1)
pendean
en respuesta a: Anonymous
There is no such thing as an "elevation panel" in the MAC program: your "suggestions" may be from other programs altogether like AutoCAD ARCHITECTURE which only runs in WindowsOS. Go back there and read the software being used to confirm, then sign up to use that software.
OR... if you are creating content in 3D you can simply change the UCS orientation to look at your drawn elevations.
en respuesta a: pendean
Thank you for your comment and advice, I need help inserting elevation
lines
