05-29-2019
12:48 PM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
05-29-2019
12:48 PM
I am working on AutoCAD LT for Mac.
When I use the LAYMCH command, I select the objects to be changed then, when prompted to select an object on the destination layer, I select a block.
Rather than moving the objects to the layer than the block is inserted on, AutoCAD is moving the selected objects to the layer that the block's linework is drawn on in the block definition (typically layer 0).
I've never had this occur with other versions of AutoCAD, and I'd really like it to stop.
Any suggestions?
¡Resuelto! Ir a solución.
