760 Vistas, 4 Respuestas
Autocad 2019 LT for Mac - saving customisation
Upon Exit message “Cannot save customization” even when customization is not done
Command – “Tools” “Customize” Interface” – freezes the program
Etiquetas (1)
maxim_k
en respuesta a: Anonymous
Welcome to Autodesk Forums!
Hi Susantha,
Looks like AutoCAD cannot write information to its support folder inside Home Library folder on your Mac.
You may try to reset AutoCAD (menu AutoCAD -> Reset AutoCAD)
Or even clean reinstall:
https://knowledge.autodesk.com/support/autocad-for-mac/learn-explore/caas/sfdcarticles/sfdcarticles/...
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
problem solved thanks
maxim_k
Can you elaborate how it was resolved?
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Hi
Can you elaborate how you solved the problem as I am unable to save a template so I don't need to reset all the parameters every time
