525 Vistas, 1 Respuesta
Trim Error
when i enter the trim command and double-click it to mane a general selection, it doesn't trim the line intersecting the 2 lines! Instead it partially trims the line.1. As you can see the selected line is a whole1. As you can see the selected line is a whole2. after double clicking- instead of erasing the line till its intersects the vertical line, it only erases half of it2. after double clicking- instead of erasing the line till its intersects the vertical line, it only erases half of it
