525 Vistas, 1 Respuesta
05-21-2019
07:56 PM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
05-21-2019
07:56 PM
Trim Error
when i enter the trim command and double-click it to mane a general selection, it doesn't trim the line intersecting the 2 lines! Instead it partially trims the line.1. As you can see the selected line is a whole
2. after double clicking- instead of erasing the line till its intersects the vertical line, it only erases half of it
05-21-2019
09:21 PM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
05-21-2019
09:21 PM
Welcome to Autodesk Forums!
Hi Jhanvi,
I think the lines in your drawing are not on the same construction plane, plus, view direction is not perpendicular to XY plane of current UCS.
So try to use PLAN command to set view direction perpendicular to XY plane of current UCS:
https://help.autodesk.com/view/ACDMAC/2019/ENU/index.html?guid=GUID-3779DF52-AA24-47D2-B72C-018D4A90...
Then use FLATTEN command (hope you are using 2019 AutoCAD version) to flatten all objects in your drawing:
https://help.autodesk.com/view/ACDMAC/2019/ENU/index.html?guid=GUID-0E2744A7-AAB9-4AE9-9614-5697668C...
Maxim Kanaev
Architect
MARSS
Hi Jhanvi,
Maxim Kanaev
Architect
MARSS
