maxim_k
en respuesta a: Anonymous
>>>>>Will changing this percentage effect other visual markers in a drawing, like intersections, etc
No, it affects just points.
>>>>> Why is the default so big i wonder.
This is a question for the program developers. You can always change this value in your working template drawing and get the size you need.
>>>>what is the logic behind the command where it is.
>>>>From "draw", to "point", to "divide", seems strange and not intuitive.
That is because of the nature of DIVIDE command - it creates a series of points along the object you want to divide (not to break at these points), so AutoCAD actually DRAW objects (points).
>>>>Isn't dividing an object a modification of the object?
No, it is not (see above)
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
